Move exceeds maximum extrusion suddenly appears
Printer Model: Prusa i3MK3S+
MCU / Printerboard: Einsy
Host / SBC: PRi 5
klippy_max_extrusion.zip (2.1 MB)
I have never entered this problem. The printer was working fine this morning but all of a sudden, it keeps giving me this error messag:
Move exceeds maximum extrusion (83.260mm^2 vs 50.000mm^2)
See the ‘max_extrude_cross_section’ config option for details
Could you please let me know how to fix it? I am using Orca Slicer.
Hi @printeruser ,
From your klippy.log, the it looks like the error occurs a few seconds after bed meshing. Are you using any purging logic in your slicer or print start macro? Could you please upload the problematic G-code?
Thanks. I came across a post that this could be caused by switching from PLA to TPU. It has something to do with a mismatch between absolute and relative extrusion modes. I don’t remember exactly what I did. I think after I changed M82 to M83 in the start gcode in the slicer, the problem disappeared. This is a bit inconvenience as we need to change the gcode manually whenver we switch between PLA and TPU. Why printing in TPU caused a mismatch in absolute/relative distances for extrusion?
Hi @printeruser ,
There shouldn’t have been an M82 in the slicer’s start G-code from the start anyway. It should have been M83.
Are you referring to the printer’s Start G-code or the filament’s start g-code?
