Printer Model: Ender 3 pro
MCU / Printerboard: BBT S3 V2
klippy.log attached
Hello all!
You can see by my name that I’m out of my depth.. I’ve got klipper onto my old ender 3 pro. It has a sprite pro extruder on it so it has a movement range of:
X - 217
Y - 230
Z - 220
I can’t figure out for the life of me why its not working? it keeps saying move out of range. I would class my self as an absolute novice about these sorts of things so please any help/advice will be greatly appreciated ! The simpler you explain it the better..
It does a bed mesh fine of 4x4 at 180x180? Does that have any relevance?
Thanks!
klippy.log (7.1 MB)
Hello @3dprintnoob92 !
There are various MOR messages. Last one is this:
Move out of range: -2.100 20.000 0.280 [0.000]
From the log it happens when you print.
How did you setup the print origin in the slicer? Center or lower left corner?
BTW:
Please don’t curse
Used orcaslicer centre of the bed. Thanks!
On rectangular beds, you always have a corner as origin. Usually the bottom left one on cartesians. Center origin is for Delta printers.
How do i adjust the orgin? Is it a slicer issue? Thanks
I’ll give this a go after work and report back! Thanks for your help
Turns out i must of already done this. this is what i have it set to before.
It was the start g code that Orca slicer was generating, it was sending X to -2.1.
Fix was to manually change the g code to 0. All fixed
