Move out of Range during Mesh Calibrate
Hi Eddy…
I am getting the same error on a CR10-S 300x300x400 SKR E3V3 BLtouch with Sprite Extruder.
Ive tried your above suggestion (with diff pinouts of course) Still getting same error as this topic…Move out of range 354.3 5 5 (0)
When prob starts to do mesh level, it fails at the 4th point on a 5x5 (25 points) test bed.
Could you do your magic and tell me whats causing this? printer.cfg attached.
printer.cfg (9.6 KB)
Hello @Obs1234 !
Due to the age of the other thread, I made a new one.
Please attach the klippy.log to your next post.
Ok…need to wipe the sonic pad and do everything I normally do to create the error…
Tnx for this…
Hokay…so…I tried changing the mesh bed size from 5x5 to 9x9. Seems both are failing at the lower right corner same spot. I am using end stops.Attached is the log…I really hope this helps!!
log_test.zip (55.8 KB)
You may read this on the Sonic Pad:
So…I’m SOL then…
See Understanding X and Y Axes Limits and Homing
