Multi-point PID calibration
I built a custom hotend with a powerful heater cartridge and a small thermal mass in the heater block. This combination created significant temperature oscillations during printing:
Standard PID tuning at 280°C: When printing at 250°C, temperature fluctuations exceeded ±10°C
I tried to implement an adaptive PID that:
  1. Calibrates PID parameters at multiple temperature points (e.g., 210°C, 220°C, 230°C… 280°C)
  2. Stores a lookup table of temperature → (Kp, Ki, Kd) mappings
  3. Dynamically selects PID parameters based on the current target temperature during operation
After calibrating 8 temperature points (210-280°C with 10°C steps) temperature fluctuations reduced from ±10°C to <±3°C across the entire temperature range
The adaptive PID controller uses a “nearest neighbor” approach:
  • Stores calibrated PID values: pid_table_0: 210.0:29.389:9.796:22.042
  • At runtime, selects parameters from the closest calibrated temperature
Configuration example:
control: pid
pid_table_1: 220.0:30.123:10.012:22.456
pid_table_2: 230.0:31.456:10.234:23.012
# ... more calibration points
Calibration command:
PID_CALIBRATE HEATER=extruder TARGETS=210,220,230,240,250,260,270,280
Implementation: link
Would this be useful?
Yes. I’ve been looking for something like that to work with multiple materials.
Right now, I use different printers for different materials.
Interesting, it seems that you can simply interpolate the datapoints to some degree
While useful can’t this be accomplished using macros without changes to klipper code?
I use a macro package (Klipper Printer Additions 3.0b9.1 - More Than Boring Start-G-Code by Christian Vick | Download free STL model | Printables.com) that accomplishes a similar function with bed mesh VS temperature. It seems it wouldn’t be hard to generate a macro to generate PID values for a range if temperatures and then insert the correct values from the start print macro.
Even what you described requires changing the original code too… And don’t you think that tuning the PID in the slicer, rather than in the firmware, is illogical?
Something like that?
def _interpolate_pid(self, target_temp):
    for i in range(len(self.pid_table) - 1):
        t1, kp1, ki1, kd1 = self.pid_table[i]
        t2, kp2, ki2, kd2 = self.pid_table[i + 1]
        if t1 <= target_temp <= t2:
            ratio = (target_temp - t1) / (t2 - t1)
            return (
                kp1 + (kp2 - kp1) * ratio,
                ki1 + (ki2 - ki1) * ratio,
                kd1 + (kd2 - kd1) * ratio
    if target_temp < self.pid_table[0][0]:
        return self.pid_table[0][1:]
    return self.pid_table[-1][1:]
Is it a good idea to use interpolation in the case of PID?
It looks like interpolation.
IDK about good or bad here, but based on points what you showed as example config:
the interpolation error seems to be too small to worry about.
Also, you can always add points and so increase resolution and decrease the error.
(And more sophisticated fit methods would be just an overkill)
Thanks.
A linear interpolation is - however within the limits of accuracy (ambient temperature, material, print speed, etc) - an approximation.
But I think it is accurate enough.
I’m hoping it’s not just interpolation but actually running multiple PID tuning steps.
I realize that makes the PID turning operation much longer to run but, if it means accurate PID values for different temperatures, then I think it’s worth it.
You’re right - linear interpolation is an approximation, and factors like ambient temperature, airflow, and print speed do affect the optimal PID values. However, for my use case (custom hotend with high power/low thermal mass), even the approximation through linear interpolation showed significant improvement over single-point tuning. The main benefit is that the controller adapts to the drastically different thermal dynamics at 210°C vs 280°C, rather than using parameters optimized for only one temperature.
Yes, it runs full PID autotuning at each temperature point
My 2 cents about implementation.
It seems to me, that adding another pid complicate the code more than it is required. You would have better chances (I think so) if it is incorporated within current one.
The only difference is the allowance to set several value triplets. So simple backward compatible assumption that current triplet is (for example) always at zero temp (or simply min/max), could be enough.
Same for the calibration, if there is only one pid and so the calibration code, you can simply modify it to append/replace 1 value at a time if it is required.
Hope that can slim the actual implementation.
I considered merging into existing ControlPID but chose a separate class to avoid modifying original logic for now.
Any news on this?
I would like very much to try it
I’d be curious to know how MPC (feed-forward control) would work on your hotend. Have you tried that (it is included in danger klipper) Model Predictive Control - Danger Klipper documentation
It is working, so what do you want?
I was unaware of this, but I should likely try it, as it is probably a better solution than mine…
I would not put it that way. From a generic perspective, PID has limitations.
One of the limitations is that tuning is done in specific circumstances, and basically speaking, with specific gain/loss circumstances.
Your approach is completely valid, to make PID fit in a wider temperature range, if it is necessary.
Basically, I would say this is the only solution within the pid loop, I think.
Another one can be to increase PID frequency/decrease command lag, for example, but it should not directly influence your case, I think.
If there is a will to look at the feed-forward, I personally think that a more generic solution can have better versatility: RFC: Cooperative Heaters predictive control by nefelim4ag · Pull Request #6837 · Klipper3d/klipper · GitHub
But from my point of view, it is a little bit out of scope for PID parameter tuning.
Thanks,
-Timofey.
JFYI:
You can enable debug logging by uncommenting and replacing logging.debug → logging.info: klipper/klippy/extras/heaters.py at master · Klipper3d/klipper · GitHub
From my updated understanding, we want the average power to be provided by the Ki, and oscillations dumped by the Kd.
It is hard to guess what is happening without log,
my pure guess is that you can reduce Ki a little, and try to reduce the Kd, and that can help.
So, for example: Kp: 30, Ki: 7, Kd: 15
So, Ki would be laggy, but should still provide average value, where Kd will be less aggressive and should dump itself, I guess.
-Timofey.
@minicx, sorry to bother
Can you give it a try?
  1. PID_CALIBRATE .. MAX_POWER=1 - it should be sane
  2. Check how it is holding temperature, for example, 250 °C
  3. Remember the average power from 2
  4. PID_CALIBRATE .. MAX_POWER=<average power +5% or so> - ideal case for calibration, where we have many samples, it is asymptote & etc
  5. Same test, how does it go
Thanks,
-Timofey
