Multible klipper(4) instances on btt-pi
Printer Model: ender 3 ish
MCU / Printerboard: creality 4.2.7
… I cannot open a file in klipper I use the browser window to run this and I load file like I normally do for the creality pad but when I load the file it shows up in the btt-pi folder for this instance… I am running 4 instances I can move all the heads and control temps and get a mesh … I just cannot print it just says it cannot open file I need to get this figured out I have a lot of printers to get running and I love klipper
thank you for any and all help
I used kiauh to install the 4 instances I have read and changed all the printer .cfg and mainsail.cfg and moonraker.conf
klippy.log (45.2 KB)
mcu 'mcu': Unable to open serial port: [Errno 11] Could not exclusively lock port /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0: [Errno 11] Resource temporarily unavailable
Looks like your printer boards all or some of them register with the same connection serial. You could try /dev/serial/by-path or make yourself familiar with UDEV to construct unique endpoints.
Thankyou for your reply you guys are awesome I will be trying that tonight
