Need help cr touch wont work
Printer Model: Ender 3 S1 Pro
MCU / Printerboard:
klippy (8).l
Host / SBC MAINSAIL
printer.cfg (11.5 KB)
X and Y both home when z starts to home it says endstop_z still triggered after retract. if it doesnt say that the extruder just rams into the bed. im not very good with printers or coding really. thanks for the help. much appreciated!!!
Hi @Ulfhednar33 ,
Make sure you follow the initial tests described in the Klipper docs:
I am running a Pi Zero 2w with the original 401 main board on my Ender 3 S1 Pro, here is CR Touch setting:
[bltouch]
sensor_pin: ^PC14
control_pin: PC13
x_offset: -45.0
y_offset: 0
#z_offset: -1.12
probe_with_touch_mode: true
stow_on_each_sample: false
samples: 3
sample_retract_dist: 6.0
samples_result: average
samples_tolerance: 0.140
[safe_z_home]
home_xy_position: 147.5, 117.5
speed: 75
z_hop: 10
z_hop_speed: 5
Make sure to uncomment and add your z_offset before saving.
The “official” sample config for your printer can be found at
It seems you are able to connect so firmware should be good. If you downloaded a .bin from somewhere I recommend you recompile. Make sure to set the correct MCU when you “make” your firmware.
