Need Help Flashing Ender 3 V2 (4.2.2 GD32F303)
tryed this config and the guides on top
allso tryed with and without swd
and i get the chip and board by opening the printer and looking on it with my eyes
Have you looked at the board?
Years ago I had a Sovol printer with a creality 4.2.2 board. After the 3rd one failed (under warranty) I reclaved it with a 4.2.7
The boards look identical but several pin names change.
When I put klipper on the 4.2.7 I used:
# This file contains pin mappings for the Creality "v4.2.7" board. To
# use this config, during "make menuconfig" select the STM32F103 with
# a "28KiB bootloader" and serial (on USART1 PA10/PA9) communication.
# If you prefer a direct serial connection, in "make menuconfig"
# select "Enable extra low-level configuration options" and select
# serial (on USART3 PB11/PB10), which is broken out on the 10 pin IDC
# cable used for the LCD module as follows:
# 3: Tx, 4: Rx, 9: GND, 10: VCC
# Flash this firmware by copying "out/klipper.bin" to a SD card and
# turning on the printer with the card inserted. The firmware
# filename must end in ".bin" and must not match the last filename
# that was flashed.
