New way to check for errors
Hi everyone! Recently I have been working on a new way to catch errors during a 3d print, which can catch errors during the 3d print faster than normal spaghetti detectors. It takes an image after each layer and then compares it with the previous one to check if the object moved. It checks for movement because movement causes spaghetti since then it is printing in mid-air. Everything works, even though there are some things I could improve. You can check it out here. All feedback will be greatly appreciated.
Do you have some example video that you can share (to see what to expect before installing your code)?
Sure, I will put one up as soon as I can, since in my tests, I just made drastic changes of movement (meaning I moved the camera away) just to speed up testing. But I will get a normal one up as soon as I can.
