"No trigger on probe after full movement" the extruder continues to release and rest against the table
Printer Model: voron 2.4
MCU / Printerboard: spider and raspberry pi 4
the message “No trigger on probe after full movement” appears, and when probing or probing at 4 points. More precisely, when checking, some points at QUAD_GANTRY_LEVEL do not work out and the extruder is released further, although the sensor itself has triggered. And other points work out correctly.
klippy.log (796.8 KB)
crowsnest.log (25.3 KB)
Mainsail is just a webinterface and can only show you the error message from Klipper. pls move this post to General Discussion. This could be a wrong pin in your config, or a broken wire.
