sergio
November 22, 2024, 9:31pm
1
Printer Model:
MCU / Printerboard:
Hello, very good, I have a configuration problem when I load a model in Mainsaill it loads out of place I attach the image and the printer cfg if necessary, I await instructions, very grateful in advance
klippy (2).zip (2.1 KB)
sergio
November 22, 2024, 11:34pm
2
I have attached klippy log and printer.cfg
How are your printer settings here:
BTW:
The klippy.log does not seem complete. Did you cut something off?
sergio
November 23, 2024, 11:09am
4
Are you referring to Cura Ultimaquer or Mainsail?
sergio
November 23, 2024, 11:18am
6
klippy (4).log (6.8 KB)
Here you have the klippy.log and the machine configuration
printer (1).cfg (2.4 KB)
In your printer config, the print area is 235 x 235
In your Cura settings you have 330 x 330.
What is the real area of the print bed. That area is decisive for the config and the slicer.
In your klippy.logs there are only error messages, but no config data. Where is that gone?
sergio
November 23, 2024, 11:29am
8
330 Y.330X 400 Z
meteyou
November 23, 2024, 12:57pm
9
there are multiple “issues”… your klippy.log doesn’t show a successful start, so mainsail only use “fallbacks”. the fallback for the gcodeviewer is:
min => 0
max => max from the gcode file
so it will be every time at the right/back end of the buildplate as long klipper is not starting, because mainsail cannot read a buildplate size.
next is the wrong axis sizees in your printer.cfg (as @EddyMI3D already wrote above)… so it will be also “out of center”.
sergio
November 23, 2024, 1:14pm
10
I have corrected elprinter.cfg and it follows the decent model. Can you check to see if it is correct???
meteyou
November 23, 2024, 1:20pm
11
i don’t know what you fixed in this config, but it looks like the exact same wrong printer.cfg as before.
the klippy.log would be always a better option, because we see the “rendered” config. also the serial paths and printer sections looks wrong and multiple time in this config file.
with this config, your printer should not start and i think you should fix that first and when your printer is running, you can double-check the gcodeviewer…
sergio
November 23, 2024, 1:27pm
12
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
rotation_distance: 40
endstop_pin: ^PC0
position_endstop: 0
position_max: 330
homing_speed: 50
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
endstop_pin: ^PC1
position_endstop: 0
position_max: 330
homing_speed: 50
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
rotation_distance: 8
endstop_pin: ^PC2
position_endstop: 0.0
position_max: 400
I have modified the maximum positions, paste the detail
meteyou
November 23, 2024, 2:02pm
13
this is a screenshot from the file above:
the file you uploaded is an other/old one…
sergio
November 23, 2024, 5:44pm
14
[quote=“meteyou, post:13, topic:20212”]
[/quote
can you check this??? I have reviewed it and it is modified and I still see the piece off center.
I have deleted the three tx pin arguments and restarted. What do you mean? Ask me what is necessary for me. I also find it difficult to understand certain concepts since I am very new to programming.
type or paste code here [include mainsail.cfg]
[virtual_sdcard]
path: /home/biqu/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
[heater_fan heatbreak_cooling_fan]
pin: PC7
[heater_fan controller_fan]
pin: PB15
[fan]
pin:PC6
serial: //dev/serial/by-id/usb-Klipper_stm32g0b1xx_1A0053000350415339373620-if00
[printer]
kinematics: cartesian
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
max_velocity: 1000
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
endstop_pin: ^PC0
position_endstop: 0
position_max: 330
homing_speed: 50
[tmc2209 stepper_x]
uart_pin: PC11
uart_address: 0
run_current: 0.580
stealthchop_threshold: 999999
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
endstop_pin: ^PC1
position_endstop: 0
position_max: 330
homing_speed: 50
[tmc2209 stepper_y]
uart_pin: PC11
uart_address: 2
run_current: 0.580
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
endstop_pin: ^PC2
position_max: 400
[tmc2209 stepper_z]
uart_pin: PC11
uart_address: 1
run_current: 0.580
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC8
sensor_pin: PA0
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
[tmc2209 extruder]
uart_pin: PC11
uart_address: 3
run_current: 0.650
[heater_bed]
heater_pin: PC9
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
pin: PC7
pin: PB15
[fan]
pin: PC6
#serial: /dev/serial/by-id/usb-Klipper_Klipper_firmware_12345-if00
serial: //dev/serial/by-id/usb-Klipper_stm32g0b1xx_1A0053000350415339373620-if00 #$# - Sergio's information
[printer]
#kinematics: corexy #$# - Sergio's printer
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[board_pins]
aliases:
# EXP1 header
EXP1_1=PB5, EXP1_3=PA9, EXP1_5=PA10, EXP1_7=PB8, EXP1_9=<GND>,
EXP1_2=PA15, EXP1_4=<RST>, EXP1_6=PB9, EXP1_8=PD6, EXP1_10=<5V>
# See the sample-lcd.cfg file for definitions of common LCD displays.
I have removed the tx pin arguments and modified the maximum positions of [stepper_y]
step_pin: PB10
pin_addr: !PB2
enable_pin: !PB11
endstop_pin: ^PC1
position_endstop: 0
position_max: 330
homing_speed: 50
330 X Y 330 Z 400
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
endstop_pin: ^PC0
position_endstop: 0
position_max: 330
homing_speed: 50
Sergio,
In our separate conversation I told you EXPLICITLY to include your klippy.log.
This is the most important file and provides the information that will help others help you.
Please attach a new klippy.log. This one is 3 days old.
sergio
November 23, 2024, 6:34pm
18
I downloaded it, I just reviewed it and it is indeed from November 20, how do I update it?
I have downloaded it several times and it still appears November 20
And these 111 lines is all you get?
sergio
November 23, 2024, 6:40pm
20
And these 111 lines are all you get? Also tell you that I have system updates, I don’t know if this is why incorrect information is displayed.
