Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
…Hello All!
I am trying to setup a multi mmu setup using 2 btt skr picos for the main boards. 1 board to run the x,y,z,z1 and then the other to run 4 extruders for a color mixing hotend. for some reason i keep getting an error for the step pin when it is an exact copy of the main board with the exception of having the secondary board name referencing what pins to use. What am i doing wrong here? I have includded my klippy log along with my printer config printer.cfg (3.4 KB)
just a quick observation, try taking the spaces out, im not 100% sure but that might be causing a parsing issue
step_pin: multi: gpio14
should probably be
step_pin: multi:gpio14
Beyond that, your extruder definitions seem to be a bit off.
Check here for using multi separate extruders:
If your running an Xin1 out hotend, you likely need to use extruder stepper definitions as the old shared heater method has been depreciated (i think thats where you got the belted extruder config from)
Check here for the config for extruder_steppers:
youll need to set up some macros to sync the extruders, the method is documented here:
