Same stepper moving but different extruder is selected?
Printer Model: Neptune 4 Max
MCU / Printer board: Manta M8P V2.0 + CB1
Host / SBC: Mainsail
klippy.log:
klippy.zip (940.5 KB)
printer.cfg (7.7 KB)
I have 2 Extruder steppers: “extruder” and “extruder1”
they are wired correctly, into motor 5 and 6 output.
when i go to my dashboard and select an extruder, see image below:
it doesn’t matter what extruder i select, the same stepper moves on my printer. ( the left one, extruder(0) )
at first i had my steppers wired incorrectly: output 4 and 5. The same happened there but instead of the left one the right one always moved (extruder1).
so they are both capable of moving (but not in the way i tell them to)
both motors have a TMC2209 installed
Heating the nozzles individually does work.
See Switching between extruders and X-In/1-Out Non-Mixing Extruder Config and X-In/1-Out Non-Mixing Extruder - Automate SuperSlicer & PrusaSlicer Filament Swaps
Thank you, i will work on this and report back with a solution mark or extra questions
I copied and adjusted some variables in my printer.cfg, see below, and i get my second extruder moving for not even a second before klipper shuts down and gives this error:
TMC 'extruder1' reports error: DRV_STATUS: 40190060 s2vsb=1(ShortToSupply_B!) ola=1(OpenLoad_A!) cs_actual=25 stealth=1
Printer is shutdown
klippy (3).log (1.1 MB)
printer (1).cfg (8.8 KB)
it has something to do with my tmc2209 driver because when i remove it from my printer.cfg , it also doesn’t move but it doesn’t give a shutdown error.
after a bit more research i have found the cause, there is a problem with my wiring. 1 group of my stepper does beep with the multimeter but the otherone doesnt. there is nothing wrong with my stepper itself, i beeped the stepper.
