Out of Range FLSun V400
Printer Model: FlSun V400
MCU / Printerboard:
klippy-1.log.zip (996.2 KB)
Hello. I have the 1.4 version of Flsun V400 for the 600mm/s profile and did the Cura 4.13.1 configuration downloads. I ran multiple prints fine and then after a print I completed overnight, I tried to print another file and got an “out of range” message. After a few attempts, and firmware restart and new calibration and bed level, no changes, still the same messages. Move out of range: 0.000 190.000 -1.300 [374.105]. I am not sure what to do at this point, but I have attached the klippy log if someone has any input. I’m not sure how my printer can be working great to all of a sudden this. Thanks!
Hello @aletarte !
Does the model print in the centre of the bed or on one “corner”
Thanks for responding so quickly! @EddyMI3D It prints the first layer in the center and then before starting the new layer it goes all the way maxed out to the back side and stops.
Only with that specific model, or with all models?
All models. I tried two or three different STLs.
Can you attach the gcode of a small model to your next post? You may have to zip it.
FV_spring.gcode.zip (973.8 KB)
Here is the Gcode in a zip!
It’s obviously an issue with your slicer.
It inserts time lapse settings on layer change.
There is this line:
;TIME_ELAPSED:213.370950
;TimeLapse Begin
G1 F9000 X0 Y190 ;Park print head
M400 ;Wait for moves to finish
M240 ;Snap Photo
G4 P700 ;Wait for camera
G0 X-6.505 Y-17.58; Restore position
;LAYER:1
BTW: Sadly, the Cura slicer does not provide Klipper flavour - or does is now?
Ahhhh!!! Silly Timelapse. I will have to take that out all together. And unfortunately it doesn’t use full Klipper yet. People have been pushing for it, and I hope they do it in the next update. Thank you very much for you help on this. It is very much appreciated.
