Parsing error appeared after firmware update
TRONXY X5SA
MCU / Printerboard: cxy-v6-191121
Klippy.log
klippy (1).log (1.7 KB)
After updating Klipper via Fluid/system/updates, I get a weird parsing error that was not there before. Can anybody help me resolve this?
The error is related to the PFPTouch sensor I printed and installedPFPTouch
I am also having issues with temperature configuration on the Triangle labs Volcano hotend I installed. After some tinkering, I discovered that at normal temperatures this sensor reads over 500°.
Please attach your printer.cfg
Sorry, I thought that was included the clippy log. Here you go.
Here is the error I get.
File contains parsing errors: /home/pi/klipper_config/printer.cfg
[line 195]: ‘G4 P300\n’
Jonathan
printerCFG.cfg (3.6 KB)
Correct this misplaced indention
Add the missing indention on the marked items
Yes, you are right, but in case of a parsing error, we need to see the original file to assess which might cause a parsing error.
Thanks by the way. This worked for me.
