Unable to parse '' as a literal: unexpected EOF while parsing (, line 0)
Printer Model: Ender 3 pro converted to E3NG_v1.2 coreXY
MCU / Printerboard: btt skr mini e3 v3
Host / SBC BTT CB1
klippy (1).log (2.1 MB)
Hi! I’m working on converting my 3 Pro to a coreXY. Almost everything is set up, but when I added the klicky files, I started getting the “Unable to parse ‘’ as a literal: unexpected EOF while parsing (, line 0)” error. If I wipe the klicky files, it will home X and Y and then just stop. I’ve tried searching and reading everything I can find. I found a discussion where the solution was true vs True and I’ve double checked my capitalizations.
Any help appreciated.
Thank you!
variable_override_homing = '' can’t be empty in [gcode_macro _User_Variables].
Thank you! I was sure that I had tried that, but I went back and it worked! Very much appreciated!
Ok, so I am still running into the same issue. I corrected the one in User_Variables, but it is still triggering. I only see ’ ’ in the mainsail.cfg (read only) file. It appears in pause and resume macros.
Sorry if it’s a basic thing, still trying to learn the non plug and play stuff and I want to do it the right way
klippy (8).log (61.8 KB)
