Pi can’t connect to the board when “usb to can”
Printer Model:
MCU / Printerboard: BTT Kraken
I can’t connect the PI to the board when I turn on “usb to can” communication interface, but when I turn on “usb” only, everything works
printer (2).cfg (8.7 KB)
klippy (5).log (112.3 KB)
How did you get Klipper onto the Kraken?
You may have to re-make your MCU firmware. I believe it can only be one of USB or CAN.
[*] Enable extra low-level configuration options
    Micro-controller Architecture (STMicroelectronics STM32) --->
    Processor model (STM32H723) --->
    Bootloader offset (128KiB bootloader (SKR SE BX v2.0)) --->
    Clock Reference (25 MHz crystal) --->
USB Interface
    Communication interface (USB (on PA11/PA12)) --->
CANBUS Interface
    Communication interface (CAN bus (on PD0/PD1)) --->
And insert the correct ID into your printer.cfg
