Printer Model: Ender 3
MCU / Printerboard: SKR Mini e3 v2.0
Hello all,
First of all, i am newbie in this type of installation.
I wanted to install PiVPN to access remotely my 3D printer. My hardware setup is one raspberrypi 4 8gb connected via usb to printer, and rpi is connected via WiFi to my router Tp-Link TL-WR940N (router is connected to my modem (bridge) from my ISP because modem is locked by them, and i cant access to do anything).
PiVPN has been installed many, many times by me, with some changes in installation procces, but everytime i cant access my vpn to connect my printer. I wanted to install vpn because when i am away home, i can check if printer prints correctly by my webcam. One or two years ago i just did port forwarding, but it is not good and safe solution.
When I turn on my VPN on my phone (Wireguard), I have no internet connection.
I did :
pivpn -d
everything is OK…
Only 2 things are not correct (imo). When i type:
cat /etc/pivpn/wireguard/setupVars.conf
my IPv4dev
is IPv4dev=wlan0
(or wlan1
, i do not remember), there should be IPv4dev=eth0
And second thing. When i did “Packet capture”( by this pivpn troubleshooting site ), no packets reach my Rpi:
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
At the end, all the time i installed this pivpn ON pi@mainsailos:~ $
, should i install this in elsewhere ?
I do not want Octoewerywhere, tailscale etc.
