General goal: implement a progress save every layer change to allow print resuming after a short black out, brown out and also a software crash.
Many have said that a power resume won’t work well since the pi won’t know the actual location of the printhead. I’ve come up with this method which I think is balanced between easy to implement and also effective:
On every layer change, save layer z
On power back up:
- Check if the max layer Z of last print is not equals to save file layer z
- If different, immediately raise bed temp to normal printing temperature
- Raise Z by something small like 5mm
- Wait for user to confirm resume
- Home XY (Z should automatically move up with the XY home)
- if printer has both Z max and min endstop, home to Z max, otherwise decrease Z motor current and move up by Z max height, and then set current Z pos to max height before resetting Z motor current.
- Move Z back down to where unfinished layer started
- Find nozzle temp and fan value of last print and set it to that
- Get the gcode automatically after the layer z and execute from there
Currently this is what I’m working on with the part that executes every layer. I’ve written it with what I mostly learnt from going through existing klipper extras scripts.
class SaveZHelper:
def __init__(self, config):
self.printer = config.get_printer()
self.printer.register_event_handler("klippy:connect", self.handle_connect)
def handle_connect(self):
kin = self.printer.lookup_object('toolhead').get_kinematics()
def do_save_z(self):
toolhead = self.printer.lookup_object("toolhead")
curpos = toolhead.get_position()
cur_z = curpos[2]
# todo read from cfg
with open("/home/user/progsafe.txt", "w") as save_file:
save_file.write(str(cur_z))
class SaveZ:
self.SaveZHelper = SaveZHelper(config)
gcode = self.printer.lookup_object('gcode')
gcode.register_command("SAVE_Z_PROGRESS", self.cmd_SAVE_Z_PROGRESS, self.cmd_SAVE_Z_PROGRESS_help)
cmd_SAVE_Z_PROGRESS_help = "save current z progress"
def cmd_SAVE_Z_PROGRESS(self, gcmd):
self.SaveZHelper.do_save_z()
def load_config(config):
return SaveZ(config)
Does anyone have a good idea where I should start with the resume part? I’m quite new with python so could someone experienced outline what happens codewise when the printer starts? Thanks for any help in advance.
