Print wont start from main mainsail page
Printer Model: Bedslinger
MCU / Printerboard: Manta M8p
Host / SBC: CB1
klippy.log (426.0 KB)
After last update a cant start print from main page of Mainsail but from g codes page, starts print normal.
After i click print console says this:
Unable to open file
And my virtual sdcard looks like this:
[virtual_sdcard]
#path: /home/biqu/printer_data/gcodes
path: ~/printer_data/gcodes
on_error_gcode:
RESPOND TYPE=command MSG=‘Vritual SD error triggered. Starting CANCEL_PRINT’
CANCEL_PRINT
PRINT_END
Hey!
yes this is a bug in the current release. Its already reported and fixed (but not released).
here is the bug report: Unable to open file when printing from home screen · Issue #2073 · mainsail-crew/mainsail · GitHub
and the pull request to fix it: fix: fix print start from dashboard for subdirectory files by meteyou · Pull Request #2074 · mainsail-crew/mainsail · GitHub
If you find something like that, pls check first our github issue tracker (also the closed one. for example this one is already fixed in the code, so the issue is closed) to check if we know this bug already or not. or maybe its already reported, but then pls also write short post into that with additional informations to it. (more posts/reactions in a issue will push this issue to the top of our todo list)
