Printer.cfg for Kywoo3D Tycoon IDEX [MCU: MKS Robin Pro 1.0]
Hello everyone,
for the unfortunate owners of this printer
[Kywoo3D Tycoon IDEX] who want to convert it to Klipper,
here is a printer.cfg ready to use.
As you all know Kywoo3D has closed, so it is not possible to find hardware or software support, so I think it was a good idea to convert my IDEX to Klipper.
If you need any help, for what are my skills regarding my experience with this printer, and the difficulties that I encountered to complete this work, write to me, I will be happy to help you to the limit of my technical skills.
I hope I have done something appreciated.
Regards.
Neo - Italy
Printer Model: Kywoo3D Tycoon IDEX
MCU / Printerboard: akerlab MKS Robin Pro 1.0
Host / SBC: Creality Sonic Pad
printer.cfg (12.5 KB)
Hi Guys.
In case you need it,
I have also prepared a [PRINT_START] script to add to your slicer that will set up some useful settings for your Kywoo3D Tycoon IDEX.
There is also some G-code included that will do some purging before printing starts.
Below is my G-CODE:
BED_MESH_PROFILE LOAD=default  ; Carica il profilo di mesh di livellamento (se esiste)
M140 S55  ; Riscalda il letto a 55°C (senza attendere)
M104 S150 ; Riscalda l'estrusore a 150°C (senza attendere)
M190 S55  ; Attendi che il piano raggiunga 55°C
M109 S150 ; Attendi che l'estrusore raggiunga 150°C
; Ora inizia a riscaldare la temperatura finale in base al profilo del filamento
M140 S[first_layer_bed_temperature]  ; Riscalda il letto alla temperatura del profilo del filamento
M104 S[first_layer_temperature] ; Riscalda l'estrusore alla temperatura del profilo del filamento
M190 S[first_layer_bed_temperature]  ; Attendi che il piano raggiunga la temperatura del profilo del filamento
M109 S[first_layer_temperature] ; Attendi che l'estrusore raggiunga la temperatura del profilo del filamento
M82  ; Modalità estrusore in assoluto
G28  ; Home su tutti gli assi
; G29  ; Esegui il livellamento automatico del piatto (se supportato)
G1 X0 Y0 Z5 F6000  ; Solleva l'ugello di 5mm dopo l'homing
M107  ; Spegne la ventola
G90  ; Posizionamento assoluto
; Inizio script linee di spurgo
G92 E0  ; Azzeramento dell'estrusore
G1 X0 Y7 Z0.25 F6000.0  ; Sposta l'ugello alla posizione iniziale
; Prima linea di spurgo
G1 X120.0 E18.0 F1500.0  ; Esegue la prima parte della prima linea di spurgo
G1 X200.0 E32.0 F1500.0  ; Continua con la seconda parte della prima linea di spurgo con un estrusione maggiore
; Spostamento per la seconda linea di spurgo
G1 X0 Y10 Z0.25 F6000  ; Sposta l'ugello alla posizione voluta
; Seconda linea di spurgo
G1 X120.0 E18.0 F1500.0  ; Esegue la prima parte della seconda linea di spurgo
G1 X200.0 E32.0 F1500.0  ; Continua con la seconda parte della seconda linea di spurgo con un estrusione maggiore
; Leggera retrazione per evitare blob
; G1 E-2.0 F1500.0 ; Mi causa un problema di retrazione del filamento inaspettato
G92 E0  ; Azzeramento della posizione dell'estrusore
I think it is a great starting point for your Kywoo3D Tycoon IDEX.
Regards.
Neo - ITALY
Thanks for providing the relevant information. Please be so kind to format it properly according to Language Highlighting for Klipper Configuration and Macros
Sorry Sineos,
I didn’t know this rule.
Now I have aligned my macro according to the rules.
I apologize again.
Regards.
Neo - Italy
Interesting.
How do you switch between the extruders and how is the second x-axes implemented?
Hi Heddy,
the printer.cfg is already configured for the second extruder, you just have to manage it at the slicer level. I did some tests with Orca slicer but it didn’t satisfy me completely.
In any case, I’m also perfecting the use of the second extruder, creating different printer profiles.
As you know, however, using the second extruder makes you lose a lot of the generous size of the construction bed.
Neo - Italy.
