Is there anyway I can access the configuration of the neopixel led from a macro?
E.g. I have the standard neopixel section
[neopixel myled]
pin: …
How do I address it via the printer object? I can use for example printer.configfile.config.extruder.min_extrude_temp to check the temp in a macro, but not sure how do I check if the neopixel with given name is defined. Thanks
