Proble MKS PI 1.1 with ADXL345
Basic Information:Problem with MKS PI 1.1 and ADXL345
Printer Model:manufactured by me
MCU / Printerboard:
Host / SBC MKS PI 1.1
Enabling MCU RPI causes the printer to not connecting to the host
files printer.cfg and klippy log webtranfer
https://we.tl/t-WPpg23z38f
Sorry, but your issue description is quite vague - or better - lets a lot of questions open.
Also the requested klippy.log is missing. Please attach that file it to your next post.
I'm having trouble uploading files, so I sent them via WebTransfer. You can download printer.cfg and klippy.log from the following link.
The problem is this: my printer works perfectly, the error occurs when I enable the following parameters in printer.cfg
[mcu rpi]
serial: /tmp/klipper_host_mcu
[adxl345]
cs_pin: rpi:None
spi_bus: spidev0.2
After restarting Klipper, the printer no longer connects to the host.
klippy.log (643.3 KB)
printer.cfg (4.4 KB)
Uploaded the files from the wetransfer here for convenience.
Hi @alfredcollie ,
Did you follow the instructions here to setup the Pi as a host MCU?
The error in your log is:
mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
This indicates something went wrong with the setup of the RPi microcontroller.
Please make sure you followed every step in the instructions correctly and verify that klipper_host_mcu shows up in ls /tmp/
