I don't know how to git the address of my muc pi?
mcu ‘rpi’: Unable to connect
Error configuring printer
and this my PRINT.CFG
[mcu rpi]
serial: /tmp/klipper_host_mcu
[adxl345]
cs_pin: rpi:PH9
spi_bus:spidev1.1 #根据自己的spi接口实际进行修改
spi_speed:5000000
[resonance_tester]
accel_chip: adxl345
[resonance_tester]
accel_chip: adxl345
probe_points: 125,125,20
I want using adxl345 but run into this problem :melting_face:
Hi cjh,
you should follow these instructions to get an answer. Very important!
Printer Model:
MCU / Printerboard:
It would help to translate your comments (I’m just guessing, Chinese comments) in your printer.cfg to English. I guess, most guys here don’t speak Chinese.
I don’t really get the problem you described in your OP.
Good luck, hcet14
You may check the installation for rpi mcu
https://www.klipper3d.org/RPi_microcontroller.html
and
BTW:
Using Chinese writing in a config file can lead to trouble.
@EddyMI3D You might take your time, I would wait for a reply from @cjh.
hcet14
