Problem to install pyserial
I’m installing Can Bus GitHub - Arksine/CanBoot: Can Bootloader for Klipper MCUs and at that point :
For USB/UART devices: Before flashing, make sure pyserial is installed. This step only needs to be performed once:
pip3 install pyserial
I get: "pip3: command not found"
Can someone help?
regards
Joerg
I’m no expert, but I think that pip3 is part of Python 3. If you are running Python 2, try just using pip, so
pip install pyserial
the same result.
pip: command not found
OK, assuming that you are running Python 3 (run “python --version” to check), then you can install pip3 like this:
sudo apt install python3-pip
that is it. Thanks for help
