I have the following setup:
bed slinger printer
- MCU SKR 3 EZ
- MCU EBB 42 v1.2
Raspberry Pi 3B+ with MCP2515 CAN Hat (16Mhz Quartz)
5" DSI Display
no Wlan, no camera
MCU 1&2 are connected to the Pi via CAN (500 kbit/s, cable twisted, both sides terminated with 120 Ohm)
- ADXL345 (X-axis) on the EBB42
- ADXL345 (Y-axis) connected via hardware SPI2 to the SKR (not to the Pi !)
CanBoot is installed on both MCUs, flashing via CAN runs without errors.
ACCELEROMETER_QUERY CHIP=bed → works
ACCELEROMETER_QUERY CHIP=hotend → works as well
TEST_RESONANCES AXIS=X is executed successfully
TEST_RESONANCES AXIS=Y starts, but stops after a few Hz with Internal error on command: “TEST_RESONANCES” and Unable to obtain ‘spi_transfer_response’ response. The point at which it terminates is not always the same, sometimes at 24Hz, sometimes at 40Hz, not reproducible.
The log says “Got error -1 in can write: (105)No buffer space available”.
What I have done so far:
changed buffer size in /etc/network/interfaces.d/can0 from 128 to 1000
auto can0
iface can0 can static
bitrate 500000
up ifconfig $IFACE txqueuelen 1000
brings no improvement.
Next bitrate changed to 1Mbit/s,
auto can0
bitrate 1000000
reinstalled CanBoot and Klipper on both MCUs
now TEST_RESONANCES AXIS=X and TEST_RESONANCES AXIS=Y works !
but now there is almost every time an error with “Communication timeout during homing z” at Z-Homing
What can be the problem here ?
klippy (5).log (2.7 MB)
