Problem with DELTA_CALIBRATE
After DELTA_CALIBRATE, arm_length parameth doesn`t change. What it can be? Printer Anycubic Predator, BTT Octopus Pro V1.1 board, CB 1 host.
Hi @Niki4 ,
Please attach the requested klippy.log to your next post.
Hi! There is
klippy.log (1.9 MB)
DELTA_CALIBRATE will only update radius, endstops, and tower angles unless your config has distance data. Distance data gets saved by DELTA_ANALYZE after entering measurements for the calibration object and saving the results.
So, I should print caliber and measure it?
