Problem with start up temps
Problem-
The printer is taking a very long time to start a print and lowers the temps.
What is taking so long-
When I first load a file to print, my printer will load the slicers temp settings (E240 and B60).
Once the printer reaches the slicer’s settings, it will home to the center of its build area.
After homing, my printer will then change the temp settings to (E190 and B60) and wait until these
temps are reached.
Once these temps are reached it will start to print at the wrong temp settings. (E190 and B60)
I have to manually raise the temp back up to print my PETG filaments.
I think my printer is using the temps from the start print macro but I have no idea how to fix this.
I did notice this in the log file-
Error on ‘M140 S’: unable to parse
klippy.zip (201.5 KB)
Can you upload a gcode file?
That error appears at lines 1689/1690.
You have changed the printer.cfg some times after that and the error does not appear again.
