Hello, I have a problem with the leveling of annex k1, namely the point is that the printer when it starts to level it starts to curve the gantry as if the engines with them were wrong, but it is not so. I tried to overdo it and change the wiring. I no longer have ideas what could be wrong. every time there is a problem with it should be good and yet it is not. in the attachment I send the file clippy.log Please help
klippy (1).log (667.4 KB)
[printer]
kinematics = cartesian # <---------------
max_velocity = 1000
max_accel = 15000
max_z_velocity = 15
max_z_accel = 1000
square_corner_velocity = 10.0
Are you sure about that?
Isn’t it a CoreXY?
That’s right, it is CoreXY, only without edge sensors. made on sensor homming
I don’t know what I did or didn’t do wrong.: (
Then you should declare the printer as corexy in the [printer]
section.
For more information:
Sorry, and I have two x and y axes crossed. cartesian
I repeat the question: does anyone know how to fix it so that the machine starts to work?
Unfortunately your problem description is not very clear.
- Check your configuration against ANNEX-Printer-Firmware/Klipper_and_Klipper_Derivatives/K1 at main · Annex-Engineering/ANNEX-Printer-Firmware · GitHub
- Follow Klipper’s initial tests to validate that single components are working: Configuration checks - Klipper documentation → Test each component, in particular stepper and probe separately
- From the log there seem to be issues with your stepper drivers
- Consult the documentation of your board and make sure jumpers are correctly set
- Consult the documentation of your board and make sure jumpers for voltages are correctly set, i.e. USB supply vs main PSU supply
