QGL Probed points range increase
Printer Model: Voron 2.4 350x350
MCU / Printerboard: M8P V2
Host / SBC CB2
klippy (5).log (1.1 MB)
I am using a Voron 2.4 for more than a year and recentrly I tried to use the BTT-EDDY for bed mesh only, probing with Voron-TAP.
Apart from rapid bed mesh wich is nice I did not found the EDDY very satisfactory so I reverted to using the Voron TAP only, but now I get stange behavior during QGL, it fails while probed points range increase.
I checked belts, did not change any wiring, homing works fine, X / Y / Z movements works fine, STEPPER_BUZZ STEPPER=stepper_Z, Z1,Z2,Z3 works fine, in the right order and right direction.
I just cannot get what is going wrong with the configuration.
homing.cfg (7.5 KB)
printer.cfg (21.4 KB)
tap_config.cfg (3.1 KB)
tmc5160.cfg (3.6 KB)
Does this capability use any CB2 gpio pins? I found that hardware I had successfully integrated with my rpi5 (standalone development host) gpio did not work when I tried it on the M8P v2 with CB2 host. I swapped out the CB2 with a CM4 and that fixed my problems.
I used GPIO pins when working with the Steathburner and EE2209 bord and it worked fine.
Now I installed a H2 V2s Revo extruder and use the EBB36 CAN V1.2 and it did worked fine too.
Only lately QGL started to missbehave.
How stupid of me ! I mixed up the gantry corners:
[quad_gantry_level]
gantry_corners:
  -50,  400     # rear  / left
  400,  -50     # front / right
instead of
gantry_corners:
   -50,  -50     # front / left
   400,  400     # rear  / right
