Quad_gantry_level error
Printer Model: Voron 2.4r2
MCU / Printerboard: Fysetc Spider V1
Host / SBC: raspberry pi4
Probe
klippy.log (2.7 MB)
:Cartographer 3d V3 canbus
Issue:
I updated klipper this morning and after that I’m encountering problems with QGL command.
I get last upgrade of klipper on this machine recently and after that it’s working.
Any suggestions? Maybe cartographer’s software is not yet ready for last klipper’s mod?
c9d904aa9 (HEAD -> master, origin/master, origin/HEAD) HEAD@{Mon Jan 26 09:23:05 2026}: pull --progress: Fast-forward
48f0b3cad HEAD@{Tue Jan 13 11:30:22 2026}: pull --progress: Fast-forward
WeBa @bigsub !
The MCU appears to have a non fitting Klipper version:
Loaded MCU 'mcu' 119 commands (v0.11.0-234-gd32a8334 / gcc: (15:8-2019-q3-1+b1) 8.3.1 20190703 (release) [gcc-8-branch revision 273027] binutils: (2.35.2-2+14+b2) 2.35.2)
Also, have you tried with a clean setup? (See: The "dirty" Flag and the Team's Position)
Git version: 'v0.13.0-464-g48f0b3cad-dirty'
Untracked files: klippy/extras/dynamicmacros.py, klippy/extras/gcode_shell_command.py, klippy/extras/cartographer.py
Recent updates have changed the internal code.
All external custom probe extensions are broken until their authors can update them.
(at least Eddy-ng, Carto, Beacon, BD Sensor).
You can either flash the Carto board with the mainline Klipper and, by so doing, remove the custom extension, or rollback and wait for the Carto code to update.
Hope that helps.
-Timofey.
Hi @bigsub ,
From the Cartographer Discord:
Don’t updated too Klipper v0.13.0-501, it breaks compatibility.
Update to fix will be released in the coming days.
If you want, you can join their Discord:
Thanks, just seen on discord. Thanks.
