Printer Model: Voron 2.4
MCU / Printerboard: Manta M8p
Host / SBC: cm4
klippy.log.zip (1.6 MB)
When running QUAD_GANTRY_LEVEL as part of a print job, a probe failure (e.g. “No trigger on probe after full movement”) does not cause a printer shutdown. Instead, Klipper exits the SD print job (Exiting SD card print (position 0)) which seems to trigger the CANCEL_PRINT macro after the failure.
This is unexpected and potentially dangerous behavior, as continued movement after a failed probe can cause crashes or damage. (Which has happened in my case.)
Steps to Reproduce
Add QUAD_GANTRY_LEVEL as part of an SD card print start macro or print start sequence.
Position the bed or probe so that one of the four probe points in QGL will fail (e.g., bed too low to trigger the probe).
Start the print job.
Observe the probe failure and resulting behavior.
Observed Behavior
Klipper raises: No trigger on probe after full movement
Immediately after, Klipper logs:
“Exiting SD card print (position 0)”
CANCEL_PRINT is triggered even though the probe failure should have stopped motion.
This is a video of what happens. I purposely triggered the z home high to safely show the failure and reaction.
Expected Behavior
Upon probe failure during QGL, Klipper should:
Immediately abort the probe routine
Stop all further motion
Enter shutdown state, not just exit the print job
