Rapido 2 PT1000 Temp Error when isntalling
Printer Model: LDO Voron V0.2
MCU / Printerboard: SKR Pico
klippy.log (1.5 MB)
…I installed a Rapido 2 Hotend to my LDO Voron V0.2. I changed the Config for the hotend sensor in the LDO picobicial config per config reference. When I reboot it again, the fan would kick up and the thermistor would read it as 158C despite the heater cartage is at room temperature.
You might want to reflect your new temperature sensor here:
sensor_type = ATC Semitec 104GT-2
Extruder
HE0, TH0 - Toolhead PCB
Overwrites the extruder heater & thermistor connection
heater_pin: umb:gpio4
sensor_type: PT1000 # Change this to your actual thermistor type
sensor_pin: umb:gpio29
pullup_resistor: 4700
Please use the Preformatted Text feature of the forum editor for code:
Format
#   Extruder
## HE0, TH0 - Toolhead PCB
## Overwrites the extruder heater & thermistor connection
