Raspberry pi temp (MCU) on Klipper screen
Hi all!
The question as probably been asked a million time…but i can’t find a easy tuto!
How to add an icon and the temp of the MCU on klipperscreen next to the bed and extruder temp?
I’m sure it is easy to setup…but i don’t know where to look for…
Thanks for your help!
If you have defined the temp sensor for the RPi, then the sensor is automatically added to KS.
Refer to host-temperature-sensor
Thanks for your help! I got this point!
But where in the printer.cfg am i supposed to add it?
should i create a new section and add the following lines:
[mcu temp]
sensor_type: temperature_host
sensor_path:
"/sys/class/thermal/thermal_zone0/temp"
Managed to get all working (MCU+Raspi Temperature), here is what I added to the MCU section of my printer.cfg:
[temperature_sensor SKR_Pro]
sensor_type: temperature_mcu
min_temp: 0
max_temp: 100
#[mcu rpi]
#serial: /tmp/klipper_host_mcu
[temperature_sensor raspberry_pi_4B]
min_temp: 10
max_temp: 100
