I’m pretty new to Klippper, and while making the config file i repeatly get this error:
“Option ‘rotation_distance’ in section ‘Extruder’ must be specified”
even when i set the distance
step_pin: PG12
dir_pin: PG11
enable_pin: !PG13
rotation_distance: 100
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB1 # Heat0
sensor_pin: PC1 # T0 Header
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 290
does somebody has a solution for my problem?
