Hello,
I´m using a Rotary Delta Machine and found out that the gearboxes from each Axis are not 100% linear from homingswitch to several Positions. Im using a two stage belt gearbox. I connected a encoder to the axis of each arm to check several positions from the homing switches…
Would it be possible to do a linearisation-calibration?
I have something like this in mind:
→ Home Axis
→ move the Arm 10 degrees
→ measure and input the actual degrees of a reference Encoder connected to the axis
→ creating a LookUp-Table for correction values to encounter the gearbox inaccuracy
→ interpolate the correction Values for the missing Positions between each measuring point.
Just an Idea if that would be possible.
Thanks in advance
