Setting up bigtree tech MAX31865 v2 on manta m8p v1.1
custom core x/y
manta m8p v1.1 +cb1
klippy.log (2.7 MB)
I am in the process of completing my first built printer. I have everything working except for the big tree tech max31865 v2 in manta m8p v1.1 motor 8 slot set for spi with pt100 for my BTT H2 500c extruder. if anyone can point me in the right direction I would greatly appreciate it.
It needs to look something like:
sensor_type: MAX31865
sensor_pin: PD10
spi_speed: 4000000
spi_software_sclk_pin: PA5
spi_software_mosi_pin: PA7
spi_software_miso_pin: PA6
rtd_nominal_r: 100
rtd_reference_r: 430
rtd_num_of_wires: 2 # adapt!
rtd_use_50Hz_filter: True # adapt!
It worked thank you very much. With your help by the pin assignmets i was able to understand the layout.
