Setting z-offset lacks clear confirmation
Hello everyone,
I’m in the process of setting up and calibrating klipper with a Ender 3 v3 SE. My next step is bed levelling but for now I am trying to set the z-offset correctly.
I didnt receive a clear alert after setting it and there was no apparent way to check the z-offset after I set and saved it. (The current z-offset was 0 according to the display.) I was under the assumption that it hadn’t worked so just before my print started I tried to set manually the z-offset again resulting in the nozzle scrubbing over my build plate.
Thanks,
Jairo
Hello @jairobbo !
So, what frontend are you using you think that produces issues.
Let me first express my gratitude for this project. It feels very well designed. I’m a 3d printer enthusiast, and the whole process of installing klipper has been a thrill.
My frontend is MainSail v2.12.0 I believe, I installed both that and Fluidd.
best regards,
