SHAPER_CALIBRATE and TEST_RESONANCES fail with error "’ToolHead’ object has no attribute ‘cmd_M204’"
Printer Model: Anycubic Kobra Neo
MCU / Printerboard: HC32F460
Host / SBC : PC
USB-ADXL345.cfg MCU: stm32f103xe
klipper version on both MCU: v0.13.0-210-gd6d858728
I setup an ADXL345 to calibrate shaper , but running either command is failing with this error
what I think is the related klippy log part is below
can you please help resolving the issue ?
Thanks in advance
ADXL345 starting ‘adxl345’ measurements
toolhead: max_velocity: 500.000000
max_accel: 8499.922000
minimum_cruise_ratio: 5.000000
square_corner_velocity: 0.000000
Disabled [input_shaper] for resonance testing
Internal error on command:“SHAPER_CALIBRATE”
File “/home/yazan/klipper/klippy/gcode.py”, line 212, in _process_commands
handler(gcmd)
File “/home/yazan/klipper/klippy/gcode.py”, line 140, in
func = lambda params: origfunc(self.\_get_extended_params(params))
File “/home/yazan/klipper/klippy/extras/resonance_tester.py”, line 373, in cmd_SHAPER_CALIBRATE
calibration_data = self.\_run_test(gcmd, calibrate_axes, helper,
File “/home/yazan/klipper/klippy/extras/resonance_tester.py”, line 265, in _run_test
self.executor.run_test(test_seq, axis, gcmd)
File “/home/yazan/klipper/klippy/extras/resonance_tester.py”, line 151, in run_test
toolhead.cmd_M204(self.gcode.create_gcode_command(
AttributeError: ‘ToolHead’ object has no attribute ‘cmd_M204’
Transition to shutdown state: Internal error on command:“SHAPER_CALIBRATE”
klippy.log (2.0 MB)
input_shaper_USB-ADXL345.cfg (381 Bytes)
Already fixed: resonance_tester: replace missing M204 call by nefelim4ag · Pull Request #7017 · Klipper3d/klipper · GitHub
wow that was fast, amazing community and support
now i need to figure out how to update to latest pull request
That PR was merged, so you just need to update Klipper with the Moonraker update manager.
thank you
update and tested it is working fine now
