Printer Model: Ender 3 V3 SE
MCU / Printerboard: CR4NS200320C13 (MCU is GD303RET6)
Host / SBC: Raspberry Pi Zero 2 W
klippy.log: klippy.zip (3.9 MB)
Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
I have flashed my machine to Klipper, mainly referring to this and this tutorial. I have performed all the necessary tuning multiple times according to Klipper’s official documentation and Ellis Tuning Guide, however I cannot seem to elliminate this:
All the sharp (~90°) corners have periodically wavy edge which is more visibile on the Z seam side, and the Z banding is also very visible on flat surfaces. No matter what I adjust I can’t seem to get away. Also I observe minor stringing even with PLA:
Strangely, these two problems will mostly go away if I use Marlin (this modded version) instead of Klipper. Here is my Marlin config which I tried to replicate as much as possible in Klipper but does not help: eeprom_backup-20260302-161429.zip (843 Bytes)
Any help is appreciated. I have installed Klipper at least three times before go back to Marlin, and is really curious why this happens only on Klipper. I strongly suspect some misconfig but can’t figure out what.
Seems like there is not much of a difference. Interestingly this effect is much less when printing a rounded corner (though banding is still there visible and touchable), but much amplified when printing sharp corners. I tried to print two test objects after tuning (first two image is sharp corner and later two is rounded corner):
Update: I tried to tune the acceleration way down (1000mm/s for XY, 300mm/s for Z) and it improved slightly, but still not on par with what I can achieve with Marlin…
#square_corner_velocity: 5.0
# The maximum velocity (in mm/s) that the toolhead may travel a 90
# degree corner at. A non-zero value can reduce changes in extruder
# flow rates by enabling instantaneous velocity changes of the
# toolhead during cornering. This value configures the internal
# centripetal velocity cornering algorithm; corners with angles
# larger than 90 degrees will have a higher cornering velocity while
# corners with angles less than 90 degrees will have a lower
# cornering velocity. If this is set to zero then the toolhead will
# decelerate to zero at each corner. The value specified here may be
# changed at runtime using the SET_VELOCITY_LIMIT command. The
# default is 5mm/s.
I also tried to bump up Y axis stepper current a bit as some tutorial said, and it created some confusing effect (if I undo the acceleration decrease it also helps a bit, but if I keep the slower acceleration as mentioned above the banding again becomes more noticiable).
Guess that’s finally enough Klipper for me on this since for now I prefer working machine over tinkerable machine… Maybe later I’ll buy something else with official Klipper support (definitely not Creality anymore, and I’m glad I didn’t waste my money on KE which is even more ridiculous according to forum post and various tutorials), but that’s another story for future. Thanks everyone for helping
