SKR Pro + BL Touch 3.1 (BL Touch issue...)
Hi All,
Trying to configure my BL Touch 3.1 (Genuine) on my SKR Pro 1.1.
Wiring seems ok, no errors on the pins apprently, but…
When I start the MCU, the BL Touch pins is triggered and come back in place, BL Touch state is a steady red LED.
When I run the “BLTOUCH_DEBUG COMMAND=pin_down” command, the pin goes down, then the BL Touch is flashing red…
Trying next to send " BLTOUCH_DEBUG COMMAND=pin_up", nothing happens, pin stays down and BL Touch still flashing…
Here is my cfg for The probe:
[bltouch]
sensor_pin: !PA2
control_pin: PA1
Any ideas?
When you run BLTOUCH_DEBUG COMMAND=pin_down, does the pin touch the printbed?
yes, and it stays down… should i move the bed down so it does not touch?
Edited: Stupid me… I moved the bed down, and now it works fine…
Again, thanks a lot @EddyMI3D ! You’re a Star!
Great! Have fun with Klipper
I am still stuck with Klipper screen…(see my other post…!)
