Sidewinder X2 (MKS SKIPR) - org. BL-Touch Fehler
2023-02-01T23:00:00Z
Printer Model: Sidewinder X2
MCU / Printerboard: MKS SKIPR
klippy.log klippy(10).log (44.2 KB)
Hello, I have take the BL-Touch on my SKIPR. When i start the printer the BL-Touch is red and the Pin go 2x in and out. Then start Klipper and the BL-Touch is only red. No other action.
Wire: 3DTouch on Board - BL-Touch brown on GND, red on 5V and yellow on PA8
Z- on Board - BL-Touch black on G, white on S.
I want to use the BL-Touch for leveling and Endstop-Z. Please Helpme, Thanks.
Hello @matthiasbertling !
Do you have an genuine BLtouch?
You may see here:
https://www.klipper3d.org/BLTouch.html
Hallo, ja der BL-Touch ist ein original.
Habe die config danach erstellt, aber schon bei BLTOUCH_DEBUG COMMAND=pin_down kommt keine Reaktion , leuchtet weiterhin nur rot.
Welche Version hat der BLtouch?
Hallo, der BL-Touch hat die Version V3.1
Can we stick to English, please. This is an English speaking place and other users might also profit from or contribute to the exchanged information.
Then you have seen this too?
https://www.klipper3d.org/BLTouch.html#bl-touch-v3
Hallo, i have tried this, and the red light is allways on and the pin don´t get out.
