Soval Sv06 plus Wont set z height no matter what i try
Printer Model: Soval sv06 plus
MCU / Printerboard: sovals stock board
completely stock printer
my config and macros soval sv06 plus.txt (19.3 KB)
my klippy log soval sv06 plus.txt (1.5 MB)
I am having trouble setting the z height offset.
Even when i set the z min from 0 to -15 and even tried setting the probe z offset from -10 to +10 to see if that would allow me to get the z height close enough to the bed.
I use klipper regularly on a ender 3v2 and a Fl sun super racer but this is definitely a first.
The printer starts g28 perfectly, then when calibrating the z offset it will probe the bed 2 times then move up 3mm while moving the nozzle over the probe area. Which will not allow me enough room to get the nozzle close to the bed.
When i hit the 5mm threshold the printer shuts down. I get a adc out of range error, it will not reset the probe, it will not restart. I have to manually move the z steppers up to where the z probe is not triggering and it will restart perfectly.
Hello @JCFPV !
It was asked for the klippy.log. Please attach it to your next post.
If you want to provide other code snippets, please attach them as file or use the Preformatted Text feature of the forum editor. The way you did it, important information got lost.
Also write your explanation text with punctation and paragraphs. No one knows where a sentence starts or where it ends.
I fixed my post if you have time please look over them. And see what i am doing wrong thanks for your time.
Did you went by this guide?
https://www.klipper3d.org/Probe_Calibrate.html#calibrating-probe-z-offset
Absolutely
I am not having trouble doing the calibration. I am having trouble getting the nozzle close enough to the bed to set the Z offset. It probes 2 times, as it moves the nozzle over the probe point it rises about 3 1/2mm. Then enters manual leveling as i go down it hits the 5mm klipper threshold and shuts everything down. Wont reset probe or firmware. I have to manually lift until probe deactivates then restart firmware but still no Z offset set. I have tried multiple configurations and multiple probes.
Also tried to disable z hop, during leveling. Klipper wouldn’t allow it.
From your logs it looks like that Klipper shuts down due to an erroneous reading of the mcu_temperature
grafik
I do not know why, but there are reports that mcu temperatures sometimes deliver strange values.
Comment out:
[temperature_sensor mcu_temperature]
sensor_type = temperature_mcu
and see if it solves the issue
Thank you very much i will try as soon as i get home from work.
Yes, Thanks so much. As soon as i comment out its working fantastic and allowing me to set the z offset. THANK YOU THANK YOU VERY MUCH.
