Spider v3 Hotend
Printer Model: Ender 3 Pro
MCU / Printerboard: v4.2.7
klippy.log as needed
Purchased the Creality Spider v3 and installed it with out to many hassles. I ran a PID_CALIBRATE, which also was successful.
I used the newer thermistor and the existing heater element.
When i go to print, the printer will warm up to 150 degrees as the pre-heat, then error out with ‘echo: “extruder” not hot enough’.
Does anybody know what this means? There is very little chatter online and most of it i have tried. I’ve reset where the connections are and applied the heater grease to no avail.
Does anyone have an idea to try or a possible working solution?
Hello @bbrietzke !
In fact, it is needed.
I looked through the logs and it was also complaining about my z-axis. I reset the connection to the stepper motor ( which was loose ) and SURPRISE! it solved both problems.
Thank you!
