Printer Model: Elegoo Neptune 2S
MCU / Printerboard: ZNP Robin Nano V1.3
klippy.log (4.2 MB)
When pasting code or config snippets use the code tags </> in the menu above
Hello!
First problem: At the end of the prime line it will wait for 30 secs to a minute, ooze a blob of filament and then go on to as normal. I’ve read it has something to do with not setting a specific temp and maybe the slicer inputs additional wait time to reach temp. Not sure what I would change though.
Second: Bed mesh calibrate, I’m running a calibrate print area only macro, however it will run a full mesh prior to starting temp, then another one for the print job area. If you could be kind enough to help me optimize my start macro that would be greatly appreciated.
printer(1).cfg (9.5 KB)
