Stepper config for Nema 14
Printer Model: Ratrig Vcore 3
MCU / Printerboard: Octopus pro + Dht42
klippy.log. Dropbox - Error - Simplify your life
Not long ago I changed extruder to an Lgx lite (with a Nema 14). And I don’t have to have it well configured…
Since it starts printing well and before finishing the first layer, stop extruding at first a little and then not extrude anything…
I have noticed that the Nema 14, is very hot, reaches 100 degrees, measured with an infrared thermometer, not very precise, I think it is its limit temperature, also suspected that that heat or part of it reaches the filaments, softening it and hindering its extrusion
The first thing I’ve done is lower the current from 0.7 to 0 4. And although it seems to me that it has improved somewhat, it takes longer until it stops extruding, it continues to overheat
The configuration of a driver
[Tmc2209 extruder], can be split multiple contained files connected to the main config.g with include?
Or do they have to be in the same file? (although I don’t know the config.g)
Reading a little more, the results of “DUMP_TMC stepper=extruder” by console
SG_RESULT: 00000000
PWM_AUTO: 000e0024 pwm_ofs_auto=36 pwm_grad_auto=14
PWM_SCALE: 0000000e pwm_scale_sum=14
PWMCONF: c80d0e24 pwm_ofs=36 pwm_grad=14 pwm_freq=1 pwm_autoscale=1 pwm_autograd=1 pwm_reg=8 pwm_lim=12
DRV_STATUS: 800c0000 cs_actual=12 stst=1
CHOPCONF: 240284f3 toff=3 hstrt=7 hend=9 tbl=1 vsense=1 mres=4(16usteps) dedge=1
MSCURACT: 00f7000c cur_a=12 cur_b=247
MSCNT: 00000008 mscnt=8
TSTEP: 000fffff tstep=1048575
FACTORY_CONF: 0000000e fclktrim=14
IOIN: 21000041 enn=1 pdn_uart=1 version=0x21
OTP_READ: 0000000e otp_fclktrim=14
IFCNT: 0000000e ifcnt=14
GSTAT: 00000001 reset=1(Reset)
GCONF: 000001c4 en_spreadcycle=1 pdn_disable=1 mstep_reg_select=1 multistep_filt=1
========== Queried registers ==========
SGTHRS: 00000000
TPOWERDOWN: 00000014 tpowerdown=20
IHOLD_IRUN: 00080c0c ihold=12 irun=12 iholddelay=8
SGTHRS: 00000000
SLAVECONF: 00000200 senddelay=2
========== Write-only registers ==========
