Printer Model: Vzbot235AWD
MCU / Printerboard: Super 8 Pro H723 / Mellow TMC 5160 PRO v1.2
klippy (2).log.zip (1.7 MB)
message.txt (10.9 KB)
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
Hi, hope to find you all well. Please help me to get my machine working again🥲.
I was running my firmware just fine, because of the klipper updates I wanted to compile new firmware into my mainboard, I followed all the documentation and know I have issues with software Spi when connecting to the Tmc5160, only my extruder works because is a 2209 with Uart comunication. Hardware Spi works fine for some minutes and then shutsdown, but that is a known issue with this mainboard, thats why all the user using this mainboard uses software Spi. I have run software Spi with no issues until I compiled new firmware and the error messages varies, sometimes is X, sometimes the error shows Y, sometimes Z, sometimes is drv_error = 1, sometimes is globalscaler, so I think is an Spi comunication issue. Other important considerations are that klipper notifications shows that the Mhz is 399mhz when it should be 400Mhz, sometimes shows the samr error but with 401Mhz.
Also, the old firmware was compiled with a Rpi3b and this time I compiled with a Raspberry Pi 5 (Bookworm) and no errors while compiling the new firmware with Bookworm.
Thanks for your time!!
