Sv 06 nozzle keeps crashing into bed, bed level off, what do I do?
Printer Model: sovol sv06
MCU / Printerboard: v0.11.0-6-g336cc92a
I crashed the nozzle onto a model recently, and the probe got jammed up inside it’s housing. I fixed that and releveled z axis, which seems good now. However, when I home the z axis it no longer crashes, but when I try to do a print it crashes and drags along the bed, as you can see.. I can manually change the z offset to stop that, but that doesn’t seem like a long term solution. The bed also now has a noticeable slope upward as you bo back on the x axis, about .6 variance from front to back.
https://www.reddit.com/media?url=https%3A%2F%2Fpreview.redd.it%2Fyjxbsacskz1c1.jpg%3Fwidth%3D4000%26format%3Dpjpg%26auto%3Dwebp%26s%3D02528cff02ad60721cc875940b73c4ebebbba7a0
klippy.log.zip (1.4 MB)
Hello @slimjet !
As for you had this accident and fixed the probe mounting, I recommend a complete leveling of bed and a probe calibration:
https://www.klipper3d.org/Bed_Level.html
https://www.klipper3d.org/Probe_Calibrate.html
BTW: This is recommend every time you did something on bed and extruder.
I’ve done a bunch of probe calibrations, but the change doesn’t seem to stick. After I do a probe calibration, I save_config. When the printer restarts and I take the nozzle down, it STILL crashes. Doesn’t matter how many times I use probe_calibrate.
