Sv06 probe issues
Printer Model: sovol sv06
MCU / Printerboard:stock sovol board
klippy.log (949.7 KB)
yesterday
after install i did a print worked great but when it finished i got an error Move out of range: 138.412 364.990 150.360 [13291.592] the nozzle was still touching the print. so i pull the print and home it and the print head crashed into the bed i had to shut the machine off. while it was off i manually lifted the z axis then turned it on and tried again using my finger to try and trigger the probe nothing.
i deleted my config file then downloaded a well known repo from github from bassamantor did a print same thing happened probe isnt working again after only 1 print.
