Printer Model: Custom Delta
MCU / Printerboard: Pi 4 & RAMPS
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
Describe your issue: In Klipper, is it possible to toggle a pin on a RAMPS mcu between 0V output and high impedance? - i.e., tristate the pin.
Significance: I am trying to get a dual Z probing method working on a Delta printer. One Z probe is a dockable probe used only for bed mapping. The second probe is under the bed and detects nozzle contact to set the Z reference. Using cloakedcode’s dockable probe module I can get the bed mapping working well, but I can’t get the sense to swap over to use the underbed sensor. This should work if I can disconnect the sense switches for “probe docked” and “probe attached” from ground and attached instead to a pin which can be set to ground or to open circuit (high impedance) and use the pull-ups to do the rest. Setting the normally ground to high impedance should spoof a “sled attached” state.
Video of the dual probing working with clunky macros on https://www.youtube.com/watch?v=DQXM4nrcsr4
Thanks for any help you can give.
klippy.log (948.1 KB)
