Probe Z-Hop function
Printer Model: Longer LK4 Pro
MCU / Printerboard: SKR 1.4 Turbo
Host / SBC: Raspberry PI 4
Hi, I was wondering if there was in Klipper the possibility to set a z-hop for bltouch when extracted as in Marlin (configuration.h - line 1711)
My request arises from the fact that when I do any operation that needs the probe(G28, MESH, etc.) the pin bangs on the printing plate. Is it possible that I have configured something wrong?
Attached I add an example of what I mean (sorry for the quality of the video but due to upload limitations I had to compress it), which is that during the first part (0:00 - 0:05) towards the end of the homing routine the pin bangs on the glass, while in the second part (0:07-0:17) there is an example, via macro, of what I mean to achieve
Thank you very much
Video (3.2 MB)
In your [printer.cfg] it will be under your [safe_z_home] section.
Also, please attach your Klippy.log file. Even if you may not think it would be of any use to your issue, it is still a requirement when posting an issue on here.
